Has anyone added a Brake Caliper to the rear driver's side. If so details please. Thanks In advance.
Rotors, spacers and studs would be the same as the active rear side. An ideal set up would be one like this it would give you a mechanical parking break as well as 4 wheel disc:
Wilwood High-Performance Disc Brakes - Combination P-Brake Calipers
You also need 1 banjo bolt , 2 copper washers , and the 2 bolts that hold the caliber on.here is what you need to add dual rear breaks.
i found the parts at cheap cycleparts.com
plus you will need to have break lines made, this will run you about $85.00
if you have a long travel kit, the left rear trailing arm should have the brakets already there for the caliper.
705600872 - Can-AmRear Caliper
$187.64
705600684 - Can-AmBrake Disc
$26.54
705400713 - Can-AmWheel Hub
$35.99
705400791 - Can-AmWheel Stud
$8.54 you need 4 of them
